‎2005-09-22
02:58 AM
‎2023-05-30
03:25 PM
Rubia Torres
‎2005-09-22 03:14 AM
‎2005-09-22 03:31 AM
‎2005-09-22 04:09 AM
adambutler wrote:I find long thumb tacks on seats are helpful in preventing people from doing this...
We have found that in one of our standard house designs a drafter has 'fixed up' a dimension by using the custom text option. They changed the text to be 830 when the space its dimensioning is much larger.
We can see no valid use for this custom text option and would like to disable it if possible. Does anybody know how this could be done? The best I can come up with is to change it back after it has changed but I do not get notified upon dimension changes due to the fact that dimensions can not be assigned user data (at least in v7).
Ideally I would like to disable this feature alltogether. Any ideas?
Thanks,
Adam
‎2005-09-22 07:09 AM
‎2005-09-22 10:45 PM
‎2005-09-22 11:23 PM
‎2005-09-23 12:15 AM
Link wrote:That would work if you could assign the colour in a setting somewhere and make sure you get the correct print output. Or have it so these dims still print with default dim text colour.
In that case why not just change the color of that changed text? I do think that we should be able to find and select statis dim text though.
Link.
‎2005-09-23 12:17 AM
‎2005-09-23 04:31 PM
