door colors
Hello,
How can I change the color of the opening arcs of a door from orange to let's say gray? I've searched through the various parameters of the door and I can't figure how.
Thanks
Yes, it was in AC 13. The answer was in floor plan display >> uncheck "enable object's pens"
Thks again
It depends on the version of Archicad you are using.
Add your machine specs and Archicad version to your profile signature to get better help.
If it is version 13 then look in the Model View Options.
