exclamation mark (!) is not disappearing.
gigzius
exclamation mark (!) is not disappearing. after double-clicking the tab it disappears but , as soon as soon as I go to another tab and then come back to that elevation, the mark (!) is back. that happens when I use any pen set except when its custom. when pen set is custom the mark disappears. help
4 REPLIES 4
Ricardo Lopez
it didn't work thnx
I am not sure if this will help.
When I open my template and open a particular floor plan view, it automatically shows with an exclamation mark in the tab - it really shouldn't.
Double clicking the tab does not clear the exclamation mark as it should do.
If I select that view in the view map and open the view settings and then just press OK, it clears the exclamation mark.
Now if I change any settings, I can double click the tab to set back to what it should be.
Make sure that none of the view settings are 'Custom' - except for the name or ID.
thank you!
