exporting plans from plotmaker
can anyone help me to export plans and sections from plotmaker.
basically i want to get plans from my project into adobe indesign but when i save plans from archicad as jpegs or tiffs the line weights come out far too thick. i can save plans as plotmaker files and then open them in plotmaker but i cant open plotmaker images in adobe indesign.
is it possible to export images from plotmaker?
thanks
5 REPLIES 5
Eduardo Rolon
Depending on your platform, there are different options.
1)publish to pdf and place it in InDesign
2)publish to dwg, open in illustrator and link to InD.
The idea is to keep the PM output in vector format so that you don't loose resolution.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
im not sure how to publish to pdfs and dwgs from plotmaker but i'll give it a try
thanks
can you tell me how to publish to pdfs / dwgs?
thanks
Eduardo Rolon
OS type and version will help, so will reading the help files, but here is the tip;
1) file -> publisher -> publish
2) select the layouts you want
3) select the type of publish you want (pdf, dwg)
4) select the folder to publish to
5) click publish
AC27 US/INT -> AC08
another Moderator
just figured out how to do it, fantastic! thanks for the help
