‎2025-09-20
11:29 PM
‎2025-09-21
05:00 PM
i
in this section i made a pergola with beams but i can see the wood fill only in the cutting elements..what i am missing?
thnx!
‎2025-09-20 11:56 PM
Have you applied a cover fill to the beam (assuming you have used a beam for the horizontal elements). There will be a tick box in the properties of the beam where you can switch it on and define the fill to use for the cover fill.
‎2025-09-21
12:23 AM
‎2025-09-21
05:02 PM
thnx for ur reply!
here are some printscreens of what i have done...
‎2025-09-21 05:11 PM
Check the Uncut Elements settings in the Elevation Settings Dialog. Is the "Surface - Cover Fill Foreground" option checked?
‎2025-09-21
06:17 PM
‎2025-09-21
07:11 PM
sorry , still have an old version and i cant find it..
thnx for ur reply
‎2025-09-21 07:13 PM - edited ‎2025-09-21 07:13 PM
Try changing the "Fill Uncut Surfaces with" field to an option that displays the Fills.
