how to set the renovation filter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-05-22 09:54 PM - last edited on ‎2023-05-19 03:33 PM by Gordana Radonic
Isn't there a way to globally tell this program that everything I am doing is EXISTING... that all library parts are EXISTING, to have to reset each thing is a waste of time and at the other end of the project, if I didn't set a couple of items, my views dont' display correctly...
- Labels:
Labels
Renovation Filter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-23 02:46 AM
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-23 02:53 AM
Richard wrote:Then either my AC18 program and/or the Bobrow Template has a bug that does not agree with want you pointed out. I will be trouble shooting this, but can reproduce the problem over and over, so I know it isn't me.
The renovation FILTER only controls the display of what has been set already. You use the DEFAULT setting button to control the object when you're drawing. If you've got it set to Existing, then anything you draw will end up as Existing. And BTW, you can use these same default buttons to CHANGE the phase of an element.
I set everything in the renovation tool to show, to be existing, but when I choose a wall, window, toilet...they all have their own settings which default to demo.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-23 03:03 AM
It's possible that the template objects were drawn with the Demo Status on. If you are eyedroppering things, the Status is probably getting picked up, too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-23 03:06 AM
Richard wrote:where is this default button that you are talking about, please
So they will have the status of whatever they were drawn as. They were drawn with the Demo Default button on. You can do a shift-A in a 3D view and select everything in the model, and change to Existing. (unlock all layers, of course) Will take about 10 secs. Then make sure the default button is set to Existing before you draw anything else. Then pick everything that will be demolished and press the Demo Default Button. Change the default button to New when you start drawing the new construction.
It's possible that these were drawn with the Demo Status on. If you are eyedroppering things, the Status is probably getting picked up, too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-23 03:07 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-23 03:10 AM
Richard wrote:that particular picture has nothing to do with the AC18 I have, have never seen that pallette...ah, you are in AC17, I am in 18...could this be the problem here.
Look at my image a few posts up. It has a big red arrow pointing to it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-23 03:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-23 03:21 AM
Richard wrote:SUCCESS !!!!! THANK YOU SO MUCH...GUESS A PICTUE is WORTH A THOUSAND WORDS!!!
You need to turn on the Renovation Palette. (It is under the Window menu). The Renovation drop-down menu only controls the DISPLAY. You cannot control what status an object is placed on with it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-23 03:22 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-23 03:25 AM
Richard wrote:TOOK THAT LITTLE JEWEL AND PUT IT IN MY GRAPHISOFT FOLDER ON THE YAHOO TOOLBAR...THANKS FOR THAT!!!
The Help Center can be your friend:http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/user-interface-reference/con...
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
