how to share a sketch?
proto
how do i share a sketch drawing with a colleague via email?
i have drawn some 2d work in archicad & want to send that over to a colleague in archicad but don't want to send the whole 40MB archicad file - just the vector sketch info from a portion of a worksheet
what is the best way to do that?
mac ACv27/6000, US full, Sequoia 15.1.1, 2020 iMac/2023 MacBook Pro
If you want your colleague to work on or be able to open the file, then you will need to send the file, or share it via a cloud service.
Otherwise take a screen shot or maybe try saving the worksheet view as a DXF/DWG or as a PDF.
proto
Yeah, I just want to share geometry, not all the views/layouts/etc.
Ok, thanks for the reply, I appreciate it!
