We value your input!
i cannot use the wall end tool - what is the syntax for using it?
proto
for the life of me, I cannot use the wall end tool
i just want to cap the end of a simple drywall partition [3.5" stud + 1/2" drywall both sides]
what is the correct way to use this tool?
the cursor doesn't seem to react to the end of the wall at all
mac ACv27/6000, US full, Sequoia 15.1.1, 2020 iMac/2023 MacBook Pro
14 REPLIES 14
sorry, i do not understand this
DGSketcher
Legend
You need to click exactly on the outside corners or the end of the base / reference line for the wall end to work.
You cannot add a wall end to a wall on a locked layer.
I know this doesn't apply in your case, but for the benefit of others, you cannot add a wall end to a COMPLEX profile.
Unfortunately I have no idea how to help you, I haven't come across this problem yet, are you sure you are trying to attach the end wall to the corner of your partition?
Proud member of UNION.ARCHI Network
@DGSketcher & @Qualifa
I was not clicking on the exact outside corner of the wall. I am now able to use the tool.
I am only able to select one response as a Solution, but I do want to thank you both for your input.
Glad we found your problem, I would only need your likes for a response that more closely matches your solution.
However, I would advise you to pay a little more attention to the video, as it often shows the whole process of the various projected solutions from the authors.
