larger frame for level dimensions
Hello.
I would like to know if it is possible to make the distance between the text and the frame larger in the case of a level dimension in Archicad.
Thank you.
Unfortunately, the answer is NO.
The Dimension Text Dialog does not have a field to specify this.
Thank you anyway.
