layout master disappearing
Do you mean, the master layout items disappear from the layout? (I.e., while you are viewing a conventional layout) If so, I have seen this issue. I found that selecting a different master and switching it back would restore order. I haven't seen dropped master items in output.
HTH,
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
11 Replies 11
__archiben
Link wrote:
People tend to forget to use layer combos within the layouting environment too. Combos that can switch out titleblock information, stamps, notes, even entire titleblocks.
link, i think that whilst this may have been true of plotmaker, the combined model/layout layer set in AC10 is no longer conducive to working efficiently with layer combinations in the layout book.
i would recommend sticking to the 'everything on the archicad layer' rule-of-thumb for layouting until graphisoft give layers a much needed overhaul - to make working with two distinct environments more intuitive.
ben
b e n _ f r o s t
Link
I've set up about a dozen AC10 templates with layout layer combinations, and they work just like PM9.
I thought working in two different environments was quite intuitive, especially once you know the differences.
Maybe I just got lucky?
Link.
