lost ability to print pdf
I cannot print to a pdf file. When printing the pdf option does not show up. Under print set-up the pdf is not there but "temporary ArchiCAD10 publisher" shows up. If I try to use that it only stalls out and nothing happens. What do I need to do to change it back to pdf?
12 Replies 12
Hi
I have the opposite problem where my pdf's won't print. I can print pdf's but the layouts with pdf's imported into them print as blank both from the physical and amyuni printer. The local agent have not found a solution as yet.
At least the work around is easy for this one, a literal cut and paste.
thanks
Laura Yanoviak
You could try this. Also, I know this topic has been discussed on this forum, so I'd recommend a search.
Thanks Laura. I had searched under pdf but found nothing specific. Do you know of another link that is not under pdf. The local agent says they have two instances of this and the other was fixed with the latest patch but it did not work for me.
