We value your input!
SOLVED!
Click and drag borders not showing up in elevation or sections
keene kopper
After updating AC to the latest 27, I lost the ability to select and move the frame borders for the vertical and horizontal re-sizing. I used to be able to hover around where the frame boarder would be, and it would highlight, but now there is nothing. I've checked that the elevation/section range is not infinite; I've tried restarting; repairing the file; but the only way to modify at least the vertical boarders is by editing the range numerically.
Thanks for any help.
Operating system used: Mac Intel-based 14 SONOMA
TV / Film Production: Sr. Set Designer
Art Directors Guild, Local 800
Archicad Latest Version
MacBook Pro (15-inch, 2018), 2.9 GHz Intel Core i9, >32 GB 2400 MHz DDR4, Radeon Pro Vega 20 4080 MB, Intel UHD Graphics 630 1536 MB
1 ACCEPTED SOLUTION
Solution
Are you seeing a contrast in background colours, or is it all one colour?
Right mouse click in the section/elevation and activate 'Section/Elevation Range '.
2 REPLIES 2
Solution
keene kopper
Thanks! That's not an function that I use often, or ever actually. So thanks for the quick reply!
Setup info provided by author
