23 hours ago
After updating AC to the latest 27, I lost the ability to select and move the frame borders for the vertical and horizontal re-sizing. I used to be able to hover around where the frame boarder would be, and it would highlight, but now there is nothing. I've checked that the elevation/section range is not infinite; I've tried restarting; repairing the file; but the only way to modify at least the vertical boarders is by editing the range numerically.
Thanks for any help.
Operating system used: Mac Intel-based 14 SONOMA
Solved! Go to Solution.
21 hours ago
Are you seeing a contrast in background colours, or is it all one colour?
Right mouse click in the section/elevation and activate 'Section/Elevation Range '.
21 hours ago
21 hours ago
Thanks! That's not an function that I use often, or ever actually. So thanks for the quick reply!
