2021-07-10
		02:03 AM
		2023-05-19
		03:44 PM
			Gordana Radonic
Solved! Go to Solution.
2021-07-14 12:49 AM
2021-07-10 06:15 AM
proto wrote:
Is it possible my text is somehow white? or printing with zero thickness?
2021-07-10 10:16 AM
proto wrote:What you are describing is very strange. I never experienced this. As temporary solution (until you figure out where is the problem) - you can place your title block directly on layout. Also upload your PDF and PLN here - we will take a look. And by the way - which version it is?
In master, all text/linework is on layer g-title blocks.2d
On-screen view options shows that "master items on layout" is checked.
The master is visible on my sheets in the layout book.
Layout book layer combination "Layout Book" shows G-Title Blocks as visible.
I've been just trying to make pdf's. Consistently on all sheets, none of the masters appear in the pdfs.
What setting am I missing? What do I need to do?
Any assistance is appreciated, thx!
2021-07-10 04:43 PM
2021-07-10 05:18 PM
2021-07-13 02:24 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-07-13 07:21 PM
2021-07-14 12:49 AM
