‎2004-09-22
11:19 PM
‎2023-05-19
10:26 PM
Gordana Radonic
‎2004-09-24 10:20 AM
Jefferson wrote:I seem to remember each view overwriting the previous one in the set. I believe the PDFs are not named according to the views but each view is named with the same name as the previous, thereby overwriting.
Trying to publish some views straight out of ArchiCAD for client review.
‎2004-09-24 05:10 PM
‎2004-09-24 08:10 PM
Jefferson wrote:Can't get the newsgroup in this country - so it's taken till now to make time to get back into following the Talk online...
Haven't seen your name here for a while.........
This is a breeze from PlotmakerDefinitely - it's great!
but I'm not always looking to send the entire sheet, hence the attempt from AC.
‎2004-09-25 08:16 AM
kimfromzim wrote:Well, guys ...Jefferson wrote:but I'm not always looking to send the entire sheet, hence the attempt from AC.
Ideally - publishing to PDF from AC needs to work, of course. But while we wait for a fix, this is the workaround I use.
‎2004-09-25 02:34 PM
Djordje wrote:I've had no problems printing to PDF on the Mac. Perhaps I just haven't needed to do something that can't be done, but so far I've been able to do whatever I need. If only we could IMPORT pdf to PM, I would be a very happy guy.
If you define your publishing set with appropriate AC views AND your PDF writer as the specified PRINTER, meaning that you are effectively printing, you can print the stuff into a PDF book immediately. Seem to remeber there was a problem with this on the Mac?
Have to try ... long time since I did his, easier to publish to PDF in 9 (still pre-release, argh!)
‎2004-09-26 03:11 PM
Djordje wrote:Yep - but the problem is when one selects "current view" one has to resize the window for each view to exclude unwanted info, as the window shape may be different to printing intention - so each print needs to be done separately in those instances. But the booklet is great if it's not a sectioned-off part of the drawing.
If you define your publishing set with appropriate AC views ... you can print the stuff into a PDF book immediately.
‎2004-09-27 09:23 PM
kimfromzim wrote:Ooops ... got too used to PrintMarquee in 9 ... does wonders!Djordje wrote:Yep - but the problem is when one selects "current view" one has to resize the window for each view to exclude unwanted info, as the window shape may be different to printing intention - so each print needs to be done separately in those instances. But the booklet is great if it's not a sectioned-off part of the drawing.
‎2004-09-27 09:35 PM
