missing "merge to one DWG file"
hello everybody,
i have a problem with publishing archicad plan into dwg file;
here you can see the a screenshot of archicad 13 tutorial and below that is my archicad 13 64 bit screenshot.in tutorial it says you can merge into one dwg file but in my archicad there isnt any option like that?
7 Replies 7
and this is my archicad 13
and also my archicad is build 3000
windows 7 64 bit.
I have only done this with PDFs but if it is the same you need to select the folder containing the layouts you want to merge.
thank you for your answer Mr. Matthew
that screenshot is from archicad 13 new features tutorial. so they made it with dwg. and so i should be able to do it. but there is no option like that as you can see my screenshot.
As Matthew says, you need to select the folder that contains the drawings for that option to become visible. (A.01 Floor Plans)
Folder highlited for merge check box to appear:
Yes, and there is a trick.
The Publisher Set folder must be coming from Layouts.
If it was generated from Views, the option is not available.
