Bling Keeta
pdf print problem
This has just happened recently.
PDFs I created using Publisher stop printing fonts and dimensions properly.
It shows perfectly fine when I open the pdf.
It also prints fine if I save directly from Layout sheet, using Save As PDF.
Any ideas? Thanks in advance.
Ben Ling
B.L.LING ARCHITECT INC.
Vancouver, BC, Canada
Mac Pro 3.5 GHz 6-Core Intel Xeon E5
AC 20
4 Replies 4
Bling Keeta
I've found the problem myself.
PDF fonts would collapse if printed out of Adobe Reader.
Printing out of Preview solves the problem.
Ben Ling
AC 20
David Maudlin
Ben:
Similar problem posted here:
AC18 PDF weirdness
I was able to solve it by clicking the Advanced button in the Adobe Reader Print dialog, then checking the Print as Image option.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Where do you find this print as image in publisher?
Im having this same problem of overlapping dimensions and text.
I have files that have 50 plus drawings and need to use publisher for speed.
David Maudlin
The option is in Adobe Reader, not ArchiCAD. I have had this issue when printing to paper, not when creating pdf files.
David
