pdf's combined into one
It would make things much easier if there were an option to combine pdf files into one straight from the organizer.
vfrontiers
Ummmmm... there already is!
Put all PDF's into a FOLDER in the organizer.
Select the folder
Check the little box that says MERGE INTO ONE FILE.
The name of your folder will be the name of the file!
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
Thanks, Just found that out. Need them in a folder Yup.
