pen thickness problem
Hello, idk if it´s the right room for that type of question ... I am newbie with archicad so that´s maybe why this kind of problem.
I have recently upgrade from 23 to 24 and i noticed that if I use any kind of line/pen i couldn´t use thickness... 0,1 looks like 1 ... no difference...
Any help please ? It kind of hurry...
problem solved.. by myself ...about 5 minutes after this post... damn i am dumbass...
have a nice day anyway
I have moved the post as it is not really a library part issue.
It would be good if you could post the solution to your problem, so those playing along at home can learn as well.
I am assuming you just needed to turn on the 'true line weight' option?
