yesterday
Hi all,
I have an issue where pens are showing different on the sheet than in the source view. On the sheet it looks like this (the red line I want to show is shown white):
When I 'open source view', things are shown correctly:
Any ideas?
13 hours ago
It’s likely your Drawing settings are using a “layout” pen set. If you access the drawings settings, you can change the pen set to “by view” and it should match the source view.
Jan Millán
Senior Technical Support Engineer, Graphisoft
Graphisoft Certified BIM Manager
