printing
Hello,
I'm about to print some project in ArchiCAD for the first time, and I'm not sure how can I set line thickness (for walls, windows etc...). Can some tell me a way to do it? Thanks
Dontknow
Select the desired pen number for specific lines.
You can set the weight for the pen numbers.
To see the weight of the lines turn on 'True Line Weight'.
When you print it, it will print the different line weights.
When you don't want the line weights to be printed turn on 'hairline' in de print window.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
