2003-11-14
11:25 PM
2023-05-19
12:23 AM
Gordana Radonic
2003-11-15 12:28 AM
2003-11-15 01:23 AM
2003-11-15 09:17 AM
johncassel wrote:You don't have to reimport. Select all the placed drawings in Drawing usage, Properties, and check Custom for this drawing under Attribute rules (bottom of the dialog box). It should update.
archiben,
Apparently the problem that I am having is when I open a .lbk created in Plotmaker 3.0 with placed drawings. The Output Scale (Attributes) is locked (greyed out) for the previously placed drawings. If the drawings are deleted and reimported using Plotmaker 3.1 the Output Scale is adjustable.
2003-11-18 07:32 PM
2003-11-18 07:33 PM
johncassel wrote:Welcome
Djordje,
Thank you for the guidance on the custom settings. Your instructions fixed my problem.
John
2003-11-20 11:17 PM
Djordje wrote:johncassel wrote:You don't have to reimport. Select all the placed drawings in Drawing usage, Properties, and check Custom for this drawing under Attribute rules (bottom of the dialog box). It should update.
archiben,
HTH,
Djordje
2003-11-20 11:36 PM
rbissett wrote:bob
This can also be changed in Options > Preferences > Drawings Attributes..., but that doesn't seem to ungray the scale setting box.
Bob
