setting a dimension in both cm and m
Hello.
I do not seem to figure out how to make dimensions appear in two ways in the same time, meaning in cm when a under 1 meter and in meters when over 1 meter. Is it possible?
Thank you a lot.
5 REPLIES 5
Eduardo Rolon
No. Wish we could, same with Imperial Units.
Make a wish in the wish section.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Thank you a lot for your answer.
runxel
Legend
I'd like to differ.
If I understood it correctly the following option should solve your problem.
Sorry for german screenshot. You will figure it out 😉
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
Indeed. Thank you!
Eduardo Rolon
Looks like I misunderstood the question..
Thought that what was wanted was an option to have dimensions substitue based on a rule not size (which AC can do).
For example AC will not substitute 12" for 1'-0" automatically.
Thanks for the catch.
AC27 US/INT -> AC08
another Moderator
