solid fills does not hide what is behind
hi
i would appreciate your help:
i'm used to hide unwanted lines in sections and elevation by placing a white solid fill in front of them. i work like this many years. suddenly the fill doesn't hide anymore- it seems ok in the model view and in the layout, but when i'm making a plt all the "hidden" lines are shown.
if i print to pdf there is no problem.
i just re installed archicad on my computer but did it the same way as i did it in the first place. it happens also in pln's that where ok before the re-installation.
4 Replies 4
Stress Co_
Is Trace and Reference turned on?… with transparent fills??
Marc Corney, Architect
Red Canoe Architecture, P. A.
sorry- i’m using archicad 10 - where is this in archicad 10?
Eduardo Rolon
This post has some info about when something similar happened to me using AC 8.1
http://archicad-talk.graphisoft.com/viewtopic.php?t=1082&highlight=
Sorry that I don't have an AC10 license installed to try to see if it works.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Stress Co_
Trace was added in AC11.
Re-reading your post I see I was way off the mark.
Eduardo's post is more likely.
