trouble with dimensions and complex profile walls
I finally started to play with complex profile walls in AC10 since now 11 will be able to handle curved ones, but I am running into a number of problems.
First while I am able to get my walls dimensioned however I want when I first create my dim. stringline, they disappear when I move a wall (see pics') Also once the dimension line is place, I cannot add to it unless the point I want is the reference line of the wall or one of the outside edges (typically finishes which I never dimension to ) . This of course relates to my other problem with complex profiles, I am only getting the mercedes symbol over the reference line and outside edges, not over the various skins, is there some trip to being able to snap to whatever skin I want?
Finally, can anyone tell me if in AC11 they fixed the problem of complex walls returning to the default height if you change profiles. That is really an annoying "feature"
2 Replies 2
only operation between here and above was to drag the upper wall
I'm not sure about your dimensioning problem.
But I have been told that the height "feature" has been resolved in V11.
I like you have been avoiding the complex profiled walls because of this problem.
Just waiting for V11 to arrive to check it out for sure.
