Tom Krowka
update detail boundary
Say I have drawn a detail boundary on a plan and have worked on the detail by adding fills, lines, notes, etc.
Now I want to make the boundary bigger on the plan to encompass more area. Also want to retain the work I have done on the detail and simply add to it.
Can't seem to do it.....any help there?
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
3 Replies 3
David Maudlin
Tom:
Change the Detail boundary in Plan, then go to the Detail window and select from the context menu "Rebuild from Source View". Except for Dimensions being changed to static, the other 2D elements should remain.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Tom Krowka
The boundary changes, but not the clipping polygon. I can't seem to move that. It does not appear that the two are connected.
[email protected]
www.walshkrowka.com
David Maudlin
Tom:
To edit the Detail boundary in the 2D window, make sure that "Marker Range" is visible under On-Screen display Options.
David
