onestoreyllc
walls not joining
I've reviewed all of the same topics here but none of the remedies worked for me.  I can't get two of the same walls to connect with a solid line at the perimeter.  It's driving me crazy, help!
Meredith
AC26 USA - Lenovo P17 - Intel(R) Core(TM) i9-10885H CPU @ 2.4GHz - 32.0GB - Windows 11 Pro
1 Solution
It has been discussed here a few times, but it is a matter of finding the correct post.
What you need to do is turn on the end lines of the skin in the complex profile settings.
Go to post
5 Replies 5
Rajesh Patil
Try this, Select required  walls and check if there both ends are displayed in "display wall ends" settings in 2D plan section  rollout in "Wall Selection Settings" dialog.
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
That setting will only affect the free standing wall end.
It won't affect the corner connections or the door/window opening edges.
Rajesh Patil
And how about the wall reference lines, are they intersecting in required manner? Also by looking at the screen shot I think you are using Wall Structure as Basic and not Composite, I am right?
Rajesh Patil
onestoreyllc
Thanks for the response, that worked and is much appreciated.
Meredith
