windows dims in 32nd" but my prefs set to ⅛"?
heathldesign
I had this issue way back with the stair tool where i had set my preferences for dimensions to ⅛" but the stairs were in 1/32" and was told to go into the setting and description dialogue to change it, but that option is gone in AC24. my windows are now dimensioned in 1/32" while my prefs are still set to ⅛" where do i go to change this?
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
18 REPLIES 18
Aaron Bourgoin
you need to modify your Dimension Style setting for doors/windows.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / USA AC29.0.1 USA
Rhino 8.24 Mac
MacOS Tahoe 26.0.1
heathldesign
and where do i find that? i don't see it in the project prefs or the object settings.
David Maudlin
Project Preferences > Dimensions.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
heathldesign
nope. i have that set to ⅛"
Can you show a screenshot of where this Stair dimension appears?
heathldesign
it's the windows in this case.
Are you looking at a View saved from the Floor Plan?
Is the View using the Dimension Settings you modified or some other Dimension Settings?
heathldesign
it's a saved view, but it's the same in the project map. it's also a custom dimension preference, but it's the same if i go with a stock dimension setting.
David Maudlin
heathldesign:
In your screen shot (Project Preferences > Dimensions), select the 6th option from the left (Door, Window and Skylight Dimensions) to set the preference for window dimensions shown with a window marker.
David
