Yvonne
3D object disappeared after migration
I created an object using slabs/walls etc. The project was migrated and now the object doesn't appear in 3D. I can see still see it in plan.
The project was started in AC25 and is now in AC26.
There was an archive file that I opened in AC26 and the object is showing fine there. I tried to copy it across but no luck.  I have no idea what's gone wrong...
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
13 Replies 13
Yvonne
Is this what you mean by parameter list?
It doesn't generate in 3D so I can't adjust any of the parameters
Lingwisyer
Guru
Do you actually have a fill with the index 31000? Try manually setting the fills, then place a new instance of the object.
Yvonne
I tried manually setting the fills and changing the fill with index 31000 to something else. Still nothing in 3D.
in the object setting:
In the 3D Script....... does this mean its not fixable?
Lingwisyer
Guru
You will probably need someone to look at it directly if you want to fix it. I cannot do that. Other than that, you rebuild the object from scratch.
Ling.
