2021-11-22 11:00 PM
How do I find out the elevation of a column in scripting?
Slabs have SLAB_ELEVATION_TOP, beams have BEAM_ELEVATION_TOP, etc...but I can't find anything for columns. What am I missing?
Solved! Go to Solution.
2021-11-22 11:33 PM
I haven't tried it but does combining GLOB_ELEVATION with the COLU_...HEIGHT give you the right answers?
2021-11-22 11:33 PM
2021-11-23 12:56 AM - edited 2021-11-23 01:01 AM
Could try placing Elevation Label 25 on a Column, then open the Label and inspect the Master Script for example ? Column, Beam and Slab Parameters | GRAPHISOFT GDL Center
| COLU_HEIGHT |
2021-11-23 10:20 PM
GLOB_ELEVATION is what I'm looking for. Thanks for that.
