GDL
Creating a property using custom GDL parameters
Laghima
I would like to create variables (that read information from the parameters). Then be able to convert them to properties. So I can use them in the expression editor.
Has anyone tried something similar ?
Laghima
Basically I was looking at reporting a parameter (so I can schedule it). Don't necessarily need the expression editor. Write: PARAMETERS <name> in the parameters script. Create a variable with the same <name> and <type> (string, integer, real number etc..)
When scheduling, select the library part parameter., from where it is stored.
4 REPLIES 4
Hai-N
Hi, I think you can find your answer in the link below. For quick answer, read and display - yes, write - no!
Linking properties into GDL Parameters? - Graphisoft Community
The only way I have been able to write to properties is with the element ID, you can also change object parameters with the element ID so I use a code for what I put in the id to change all parameters and properties
Does this include schedule ? If I was to use multiple instances of objects ?
Laghima
