2023-04-25 05:20 PM - edited 2023-04-25 06:15 PM
This is the window I made.
Why does this phenomenon appear in cross section?
The material is the state designated as gs_sash_mat and gs_glass_mat, respectively.
2-sash Sliding Window 26
GS door: glass fill - Graphisoft Community
In this case, prism_ status code is set to 5.
So how should the frame and sash be treated?
Solved! Go to Solution.
2023-04-25 06:24 PM
In section body with same fill merged. You need set different fills in code, with sect_fill
Structural engineer, developer of free addon for sync GDL param and properties
2023-04-25 06:24 PM
2023-04-26 06:15 AM
or...make a gap between elements.
2023-04-26 06:35 AM
But what about in standard windows?
2023-04-26 01:31 PM
I thought it would be possible to use a different section fill for the surface, but I found out that wasn't possible.
Other surfaces have also been merged.
So, I decided that I had to use sect_fill.
2023-05-03 09:37 AM - edited 2023-05-03 09:38 AM
The default frame cut fill is "Background", sash cut fill is "Air space". They look the same, but are different attributes, so they don't merge.
2023-05-03 11:47 AM
thank you I understand that the section material should be different, and I decided to create and use BG_Frame1,2 and BG_Sash.
Our country is all made up of bokchang.
