2015-04-27
02:30 PM
- last edited on
2025-02-05
12:05 PM
by
Aruzhan Ilaikova
2024-06-06 07:15 AM - edited 2024-06-06 07:16 AM
You are using the parameters incorrectly.
You need to be checking for the value of the parameter.
For a boolean it is 1 or 0 (on or off).
For a text parameter you need to be using the value typed into that text parameter - in tour case "SB"
2024-06-06 07:24 AM
That's great, thank you for that.
2024-06-06 09:23 AM
For the boolean, you do not actually have to put the value, you can just write "IF [parameter] then". Using this same notation, you can utilise it within sums, usually to decide whether or not to add a value.
| AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2025-05-04 04:12 PM
Very cool, everyone! I'm also trying to learn about object creation. Could someone help me? I tried to set a fixed representation — one for the floor plan and another for the elevation/section — but I can't get anything to show up in the elevation or section views at all. Is there something else I need to do? It seemed simple in the posts.
2025-05-04 05:44 PM - edited 2025-05-04 05:48 PM
Hi everyone - As this thread has gotten deeply into GDL coding, just a reminder that there is a separate area of this Community for coding GDL objects, which covers almost all of the replies to this thread:
https://community.graphisoft.com/t5/GDL/bd-p/forum-gdl
This "Libraries & Objects" forum is primarily about using library parts and managing libraries, and does include 'save as object' type objects. The official description on his forum's page is "About Archicad and BIMcloud libraries, their management and migration, objects and other library parts, etc."
As soon as issues jump into creating or modifying GDL, the GDL forum is the right place to continue. 😀
PS I think the GDL forum is overlooked / not found, over and over, because it is "hidden" in the "Developer Hub" - yet nobody discussing GDL here would likely consider themselves "developers" and so likely never even looks at that menu. In the "old" days, the GDL forum was part of the main Community... something that the Community team might want to reconsider.
2025-05-07 10:31 PM
I have moved the topic to the GDL forum.
