‎2022-04-22 06:18 PM
Hi all,
I am trying to get the Frame Thickness using a label. Using WIDO_FRAME_THICKNESS does not seem to work ( returns 0). On the other hand, using Frame Thickness from the Property Manager does evaluate correctly. Not sure if it's a bug or I am looking a wrong Global Variable.
Cheers
Solved! Go to Solution.
‎2022-04-25 09:35 AM
this is not available for labels. You can use the parameter name with ASSOCLP_PARVALUE, or an autotext label.
‎2022-04-26 06:54 AM
@Peter BaksaThank you very much for your answer and work-arounds.
