Palawat
Frame Thickness for Window/Door
Hi all,
I am trying to get the Frame Thickness using a label. Using WIDO_FRAME_THICKNESS does not seem to work ( returns 0). On the other hand, using Frame Thickness from the Property Manager does evaluate correctly. Not sure if it's a bug or I am looking a wrong Global Variable.
Cheers
Archicad 29, Windows 10, Corei7 3.4 GHz, 32 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
1 Solution
Peter Baksa
this is not available for labels. You can use the parameter name with ASSOCLP_PARVALUE, or an autotext label.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Go to post
2 Replies 2
Peter Baksa
Péter Baksa
Palawat
@Peter BaksaThank you very much for your answer and work-arounds.
