GDL
SOLVED!
ui_infield on top of ui_pict
jc4d
Hello,
Is there a way to "force" the ui_infield to be on top of the ui_pict?
Juan.
1 ACCEPTED SOLUTION
Solution
runxel
Hero
Yes. There is a stupid workaround: You have to define the ui_infield twice. Once before and once after the respective ui_pict.
2 REPLIES 2
Solution
runxel
Hero
Ok, that is extremly odd to say at least. Thank you for the tip, now it looks much better (the ui, not that part of the code 🤣)
Juan.
