ā2023-01-17
12:51 PM
ā2023-05-31
09:48 AM
Laszlo Simon
Hi all!
Is there some way to batch change on multiple GDL-s at once Author/Object's subtype or even something that can batch replace text in scripts
e.g.
I am modeling 2D symbols and want to change mul2 from "mul2 A/0.08, B/009 " to "mul2 A/GLOB_SCALE, B/GLOB_SCALE" nothing special but it would be great to batch all symbols...
Thank you in advance!
Solved! Go to Solution.
ā2023-01-20 10:06 AM
The GDL editor will only let you edit one script of one object at a time.
As far as I know, you need to use the LP_XMLConverter tho change the format so you can edit (find and replace) and then save back.
This link may help?
https://gdl.graphisoft.com/tips-and-tricks/how-to-use-the-lp_xmlconverter-tool
I must admit I have never mastered it.
Each time I try, I look at it and think it is too hard and I just don't understand what is written.
I just edit each object I the GDL editor.
ā2023-01-17 01:41 PM
Convert to HSF (LP_XMLConverter), make your adjustments via a script or just with plain regex, convert back.
ā2023-01-18 04:42 AM
You can do a find and replace all for script text. But you have to do each script separately.
ā2023-01-20 09:44 AM
Is there a solution without using XMLConverter? If not, can you recommend a tutorial/manual so I can check it out?
ā2023-01-20 09:48 AM
Yes I know but I am looking for solution where I can lets say click "find and replace all"
but the text is replaced in all open tabs that are GDL editor.
This link may help?
