Lingwisyer
Guru
GDL: glob_modpar_name - Arrays
Hi all,
I have 2 integer parameters, x and y which are each linked to the size of 9 other array parameters, 4 unique and 5 common. These common arrays only update if the modification of x or y is greater than the other, max(x ,y).
When I modify all 9 relevant arrays update. The issue is that when I modify y, it's relevant 8 arrays DO NOT update UNTIL you modify x... This though highly inconvenient is managable as you can follow up any changed to y with an increase to x before reverting it's value inorder to get everything to update. The major issue is that there is one array (sg_customBasePrefix) that does not update at all meaning that the object breaks if you increase y beyond the existing size of this array...
The current object can be found over at this thread.
Ling.
3 Replies 3
Lingwisyer
Guru
!========== Levels Array ==========
IF sg_base_toggle then sg_noStoreyAbove = sg_noStoreyAbove + 1
IF GLOB_MODPAR_NAME = "sg_noStoreyAbove" then
	name = sg_name_prefix + STR ("%2.0", i)
	! allow decrease, vardim1 tells stored array vertical size
	sizetokeep = min(vardim1(sg_custom), sg_noStoreyAbove)
	! copy existing values
	dim sg_styToSty_temp[]
	dim sg_custom_temp[]
	dim sg_customName_temp[][]
	dim sg_customPrefix_temp[][]
	for i = 1 to sizetokeep
		sg_styToSty_temp[i]			= sg_styToSty[i]
		sg_custom_temp[i]			= sg_custom[i]
		sg_customName_temp[i][1]	= name
		sg_customName_temp[i][2]	= sg_customName[i][2]
		sg_customPrefix_temp[i][1]	= name
		sg_customPrefix_temp[i][2]	= sg_customPrefix[i][2]
	next i
	! initialize new values, will be skipped when decreasing size
	for i = sizetokeep + 1 to sg_noStoreyAbove
		sg_styToSty_temp[i]			= sg_styToSty_def
		sg_custom_temp[i]			= 0
		sg_customName_temp[i][2]	= 0
		sg_customPrefix_temp[i][2]	= ""
	next i
	! store array with new size
	sg_styToSty						= sg_styToSty_temp
	sg_custom						= sg_custom_temp
	sg_customName					= sg_customName_temp
	sg_customPrefix					= sg_customPrefix_temp
	parameters sg_styToSty			= sg_styToSty_temp
	parameters sg_custom			= sg_custom
	parameters sg_customName		= sg_customName
	parameters sg_customPrefix 		= sg_customPrefix
endIF
FOR i = 1 to sg_noStoreyAbove
	IF sg_custom[i] # 0 then	PARAMETERS sg_customName[i][1] = name
next i
!========== Basement Array ==========
IF GLOB_MODPAR_NAME = "sg_noBasement" then
	name = sg_nameBase_prefix + STR ("%2.0", j)
	sizetokeep = min(vardim1(sg_customBase), sg_noBasement)
	dim sg_basementHTs_temp[]
	dim sg_customBase_temp[]
	dim sg_customBaseName_temp[][]
	dim sg_customBasePrefix_temp[][]
	for j = 1 to sizetokeep
		sg_basementHTs_temp[j]			= sg_basementHTs[j]
		sg_customBase_temp[j]			= sg_customBase[j]
		sg_customBaseName_temp[j][1]	= name
		sg_customBaseName_temp[j][2]	= sg_customBaseName[j][2]
		sg_customBasePrefix_temp[i][1]	= name
		sg_customBasePrefix_temp[i][2]	= sg_customBasePrefix[i][2]
	next j
	for j = sizetokeep + 1 to sg_noBasement
		sg_basementHTs_temp[j]			= sg_styToSty_def
		sg_customBase_temp[j]			= 0
		sg_customBaseName_temp[j][2]	= 0
		sg_customBasePrefix_temp[i][2]	= ""
	next j
	sg_basementHTs						= sg_basementHTs_temp
	sg_customBase						= sg_customBase_temp
	sg_customBaseName					= sg_customBaseName_temp
	sg_customBasePrefix					= sg_customBasePrefix_temp
	parameters sg_basementHTs			= sg_basementHTs
	parameters sg_customBase			= sg_customBase
	parameters sg_customBaseName		= sg_customBaseName
	parameters sg_customBasePrefix	 	= sg_customBasePrefix
endIF
FOR j = 1 to sg_noBasement
	IF sg_customBase[j] # 0 then	PARAMETERS sg_customBaseName[j][1] = name
next j
!========== Grid Lengths Array ==========
IF GLOB_MODPAR_NAME = "sg_noStoreyAbove" | GLOB_MODPAR_NAME = "sg_noBasement" then
	IF sg_noStoreyAbove > sg_noBasement then
			sizetokeep = min(vardim1(sg_customName), sg_noStoreyAbove)
			dim sg_lengthCustom_temp[][]
			dim sg_lengthCustom2_temp[][]
			dim sg_lengthToggle_temp[][]
			dim lp1_temp[][]
			dim lp2_h_temp[][]
			dim lp2_v_temp[][]
				sg_lengthCustom_temp[i][1]	= sg_lengthCustom[i][1]
				sg_lengthCustom_temp[i][2]	= sg_lengthCustom[i][2]
				sg_lengthCustom2_temp[i][1]	= sg_lengthCustom2[i][1]
				sg_lengthCustom2_temp[i][2]	= sg_lengthCustom2[i][2]
				sg_lengthToggle_temp[i][1]	= sg_lengthToggle[i][1]
				sg_lengthToggle_temp[i][2]	= sg_lengthToggle[i][2]
				lp1_temp[i][1]				= lp1[i][1]
				lp1_temp[i][2]				= lp1[i][2]
				lp1_temp[i][3]				= lp1[i][3]
				lp1_temp[i][4]				= lp1[i][4]
				lp2_h_temp[i][1]			= lp2_h[i][1]
				lp2_h_temp[i][2]			= lp2_h[i][2]
				lp2_h_temp[i][3]			= lp2_h[i][3]
				lp2_h_temp[i][4]			= lp2_h[i][4]
				lp2_v_temp[i][1]			= lp2_v[i][1]
				lp2_v_temp[i][2]			= lp2_v[i][2]
				lp2_v_temp[i][3]			= lp2_v[i][3]
				lp2_v_temp[i][4]			= lp2_v[i][4]
			next i
				sg_lengthCustom_temp[i][2]	= 0
				sg_lengthCustom2_temp[i][1] = 0
				sg_lengthCustom2_temp[i][2] = 0
				sg_lengthToggle_temp[i][1]	= 0
				sg_lengthToggle_temp[i][2]	= 0
				lp1_temp[i][1]				= marker_length/4
				lp1_temp[i][2]				= marker_length/4
				lp1_temp[i][3]				= marker_length/4
				lp1_temp[i][4]				= marker_length/4
				lp2_h_temp[i][1]			= marker_length/4
				lp2_h_temp[i][2]			= marker_length/4
				lp2_h_temp[i][3]			= marker_length/4
				lp2_h_temp[i][4]			= marker_length/4
				lp2_v_temp[i][1]			= 0
				lp2_v_temp[i][2]			= 0
				lp2_v_temp[i][3]			= 0
				lp2_v_temp[i][4]			= 0
			next i
			sg_lengthCustom				= sg_lengthCustom_temp
			sg_lengthCustom2			= sg_lengthCustom2_temp
			sg_lengthToggle				= sg_lengthToggle_temp
			lp1							= lp1_temp
			lp2_h						= lp2_h_temp
			lp2_v						= lp2_v_temp
			parameters sg_lengthCustom	= sg_lengthCustom
			parameters sg_lengthCustom2	= sg_lengthCustom2
			parameters sg_lengthToggle	= sg_lengthToggle
			parameters lp1				= lp1
			parameters lp2_h			= lp2_h
			parameters lp2_v			= lp2_v
		ELSE
			sizetokeep = min(vardim1(sg_customBaseName), sg_noBasement)
			dim lp1_temp[][]
			dim lp2_h_temp[][]
			dim lp2_v_temp[][]
			next i
			for i = sizetokeep + 1 to sg_noBasement
				sg_lengthCustom_temp[i][1]	= 0
			next i
			lp1 						= lp1_temp
			lp2_h						= lp2_h_temp
			lp2_v						= lp2_v_temp
	endIF
endIF
Peter Baksa
not sure if it helps, but maybe the confusion comes from using GLOB_MODPAR_NAME. That only contains the name of the parameter which the user modified manually. It doesn't react to PARAMETERS commands in the code.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Lingwisyer
Guru
I found the issue. I had two i where there should have been j... That was why that one parameter was not updating, and apparently the reason why the others where only updating when the other set of arrays were updated... maybe I should have used letters which did not look so similar... Another facepalm moment...
Ling.
