2024-03-08
04:45 AM
2024-09-26
01:53 PM
Doreena Deng
Hi all,
I quickly modelled a tap set in the floor plan, converted them to morphs, oriented them correctly then saved it all as an object. Given it is a morth, the floor plan is a wireframe so I decided to override the generated 2D Script.
The issue is, my lines in the 2D Symbol window are invisible. I can select them, but trying to edit anything while you cannot see lines that are not selected is impossible...
Ling.
2024-03-08 05:05 AM
Can you show an image of your invisible lines? 🤣
Joking of course.
So you can select them and can see them then.
But changing pen colour has no effect?
Or changing the layer?
I assume they are 'solid' line type, and not a wide spaced dotted line?
2024-03-08 07:09 AM - edited 2024-03-08 08:02 AM
Colour change has not effect in the editting window nor does the layer. They are indeed solid.
***Well, came back from lunch, decided to try drawing the plan in a Worksheet, went to paste it into the 2D Symbol window, and what do you know, my lines from earlier were visible...
2024-04-09 03:33 PM
hehe. I also want to see those.
