GDL
SOLVED!
Policy on modifying standard library objects
well I cant really ask for money for the cabinet as it is not my property. I could however send you a detailed step by step process to add the option yourself. Its really not to difficult, and it will give you some more indepth knowledge of gdl. maybe a small paypal donation? to compensate for my wifes anger ha ha? and i guess for the time to write up the how to? Hmm...
[Update by moderator: Since Archicad 23, library part licensing has been changed to :
Attribution 4.0 International (CC BY 4.0)
https://Archicad-talk.Graphisoft.com/viewtopic.php?f=49&t=47320&start=20#p315061]
25 REPLIES 25
Jochen Suehlo
If I want to use some unmodyfied macros, and my object should work in AC 16, 17, 18 and 19 I might get the problem that there are macros with the same name in the different AC versions, but with different script content and different GUIDs. So it might be possible that i get error messages because of this.
The question therefore is: is it allowed to use the Graphisoft macros where I only change their name and their GUID, but not their scripted content and provide commercial objects together with this renamed macros?
Jochen Suehlo . AC12-28 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
Lingwisyer
Guru
If I wanted to create say a set of custom doors that utilise the default macro structure but at certain stages, call a custom macro instead, by the sounds of it, I would not be allowed to share the macro that has been modified to make a different call and would instead need to include instructions on which default macros to duplicate? Does modifying the GUID count as a modification to the object?
eg.
Scripting
I write my own casing macro.
I duplicate and modify the relevant macro(s) to call my custom macro instead of the default.
(If I wanted this to appear in the door options, I think I would need to duplicate 2 or 3 macros, unmodified, prior to the modified one.)
Sharing
I can share my casing macro and the root macros (?)
I have to provide instructions on which macros to duplicate and make call adjustments to
Ling.
There has been much discussion about this in this thread and the answer evolved. Here is the posts which you should read and that should give you a good idea of what can and cannot be done:
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=47320&start=10#p234440
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=47320&start=10#p234504
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=47320&start=10#p234713
Solution
Peter Baksa
Hi all,
Without trying to give a legal advice, the licensing of Graphisoft's library parts has changed to https://creativecommons.org/licenses/by/4.0/ from Archicad 23.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
vistasp
That's wonderful news, Peter! Glad Graphisoft made this change!
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Lingwisyer
Guru
Finally! Nice to have pure Attribution and Share-Alike options available.
