		2021-06-17
		12:04 PM
		2021-09-14
		09:06 AM
			Noemi Balogh
 Solved! Go to Solution.
2021-06-17 02:58 PM
2021-06-17 12:48 PM
2021-06-17 01:08 PM
vuego wrote:D%mn. That would be quite silly. Why then even have the line elimination flags, if they are useless?
I don't think you can do this. But you can change your layer's intersection priority to 0.
				2021-06-17 01:54 PM
2021-06-17 02:31 PM
2021-06-17 02:37 PM
runxel wrote:Or use the Poly2 command to draw the lines. I have done this in similar circumstances.
In the end I could just go very ugly and make them tubes a fraction of a mm smaller.
2021-06-17 02:50 PM
David wrote:Hey David, you mean with POLY_ set to `model wire`?
2021-06-17 02:58 PM
2021-06-17 03:05 PM
runxel wrote:Yes, my mistake, I mixed up the 2D and 3D commands. Lin_ is also an option.
2021-06-17 10:06 PM
runxel wrote:well, idk maybe i'm missing something
The example above is not TUBE{2} but a simple PRISM_.
pen 20 ! red contour material 99 ! grey material prism_ 5, 1, 0,0,15, 1,0,15, 1,1,15, 0,1,15, 0,0,15 addz 1 prism_ 5, 1, 0,0,15, 1,0,15, 1,1,15, 0,1,15, 0,0,15 del top
