runxel
Prevent (!) Line elimination
Hey folks, I have a TUBE{2} and need my lines to be NOT eliminated.
See this picture below, just two cubes (as dummy) to show the issue. If you stack them, they will join and I somehow need to prevent this from happening, since they need to be visually different.
The MASK parameter for the tube{2} is set to 1+2+16+32, which means, the line elimination flags are not set (especially looking at you, 1024!).
Yet, it still eliminates the line between the two objects.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
14 Replies 14
runxel
A. wrote:
well, idk maybe i'm missing something
In my example above it is the same object, just placed twice, so it is stacked upon each other, which will lead to the line elimination.
Jochen Suehlo
What is different in your script to the one from A. Smith, that you do not get the lines?
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
Lingwisyer
Guru
Two boxes in TWO objects vs two boxes in ONE object.
Jochen Suehlo
This is interesting, because 2 double boxes on top of each other have a separation line,
while 2 singles boxes don't have.
Peter Baksa
Hi all,
cprism_{3} can control line elimination:
cprism_{3} 0, 0, 0, 0,
	4, 1,
	0, 0, 0, 15, 0,
	0, 1, 0, 15, 0,
	1, 1, 0, 15, 0,
	1, 0, 0, 15, 0
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
