GDL
String width when using autotext
JGoode
I'm trying to get the width of a string so that I can put a background behind the text, but the string is made up of a combination of autotext and standard text. The string width seems to calculate by using "<PROJECTNUMBER>" instead of what the project number actually is.
Is there any way to get around this or fix it?
Thanks
ArchiCAD 27
Windows 10
4 REPLIES 4
Jochen Suehlo
You cannot do any GDL Operations with Autotext except of TEXT2
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
Erwin Edel
This should be possible, probably not through autotext, but with parameters.
We have some door/window markers from our local reseller that offer the option of putting a fill behind text and that text is directly pulled from the door/window, like Element ID, width, etc
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Lingwisyer
Guru
Have a look through the Requests. Can't many of the autotext values can be requested and hence and asigned to a parameter which can then be measured?
Ling.
Looking around, it would seem that project info is exempt from this...
Erwin Edel
If you're trying to make a simple title block to put on layouts, we just draw these on worksheets, save those as views and put the views on master layouts. Autotext works fine this way and you can just use the text tool.
www.leloup.nl
