GDL
The title indicates that the variable value is blank.
LeeJaeYoung
if "<Dong Name>" = "" then
     text2 0,0,1
else
     text2 0,0,2
endif
Number 2 appears. Even if you use "#", you get the same result.
How do I know if the space is blank?
AC27 on window 11
As far as I know, GDL can not read the value of the Project Info variables
That is probably why you can't determine if it is empty or not.
All GDL can do is display the value.
It will be blank if it is empty.
Yes, you have to turn it on/off as an option.
AC27 on window 11
