GDL
UI TEXTSTYLE INFIELD 2 does not show icon for superscript and subscript
Palawat
Hi everyone,
With "textStyle" as a integer type parameter and within the UI script :
ui_dialog "Test"
ui_textstyle_infield{2} "textStyle", 1+2+4+32+64+128, 280, 95, 20, 20, 2
On the Selection Settings Dialog, there's no icon for superscript and subscript. The placeholders, the tooltips, the functions are there (you can select it and it set the value correctly) but not the icons.
This happens in Archicad 28 (with the latest update ... not sure if it happens on earlier versions as well) and also the Tech. Preview 29. Can anyone confirm if this is a bug, or it's me?
Archicad 28, Windows 10, Corei7 3.4 GHz, 32 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
10 REPLIES 10
I can confirm this does not work in 28.
Works fine in 25.
Is this used successfully in any default Archicad 28 objects?
I do not use the library so I would have to go hunting to find out.
Report this to your local support to see what they say.
Thank you very much, Barry, for confirming this.
I don't really use the library either. But from what I noticed, most of the "Text" settings for default lib. don't have superscript and subscript as options. So the code might be just 1+2+4+128 . Maybe they are not needed.
Palawat
Sorry I totally forgot about this post. Turns out that I seems to not have a local support ( I am using dev. license).
Could someone from @GRAPHISOFT report this as a bug please?
Thank you so much.
I have reported this to technical support with reference to this post and have asked then to contact you or reply to this post.
Hopefully you will here something.
Thank you very much, Barry.
Kornel Beleznai
Hi there,
Thank you for raising this issue and reaching out about it.
After checking with the development team, I can confirm that this behavior is indeed a defect that has been registered as DEF-23745 in our system.
We haven't received other reports of this previously, so it appears to be a less common workflow. However, if it receives additional user attention, Product Management will review it for potential prioritization.
Thanks again for bringing it to our attention.
Kind regards,
Kornél
Beleznai Kornél
Technical Support Engineer
Thank you very much, @Kornel Beleznai .
Keeping my fingers crossed.
How can this post be marked as solved when it doesn’t work and there is a bug in the software? I read the @Kornel Beleznai response as “we are not going to fix it.”
Palawat
I was wondering if it's a bug. It's confirmed that it is. The question is clearly answered . So I marked it as solved.
I asked the question knowing that this is not the official support channel and get a response from someone from Graphisoft? That's a plus for me 🙂
If you (or anyone) have the same problem, pls make sure to report it. Maybe it'd get more priority.
