GDL
Units of Auto Script from Dropped Geometry?
Is there a way to control the units of the auto script generated from dropping drawn geometry into a script window? For many years it seemed to follow the working units, or at least I was OK with it being FFI in USA usage. Now all the values are always metric, and run to 13 decimal places, which is not easily -readable for this human. And since the geometry in question is often FFI, I'd greatly prefer to see those values in the script.
e.g.:
🛑0.05715m
2.25"
James Murray
1 REPLY 1
Zsuzsanna Bori
Unfortunatley, no. The length in GDL is always in meters. You can find a good workflow for working with constants in your code in the comments of this thread.
Regarding the decimal places, you can always round up a few numbers at the end if you are comfortable with losing the original geometry's precise size, but the best part of this drag&drop feature is that you don't have to figure out these complicated numbers yourself, the computer does it for you. 🙂
