GDL
Use GLOB_STRUCTURE_DISPLAY with WALL_SKINS_PARAMS
Arnaut_2604
Hi there,
I working on a wallclosure for a window with WALL_SKINS_PARAMS which so far works pretty well, the only issue is that I doesn't react to the GLOB_STRUCTURE_DISPLAY setting.
As far as I found there isn't a Parameter in WALL_SKINS_PARAMS which defines whether the layer is Core/Finish/other.
Can this be requested somehow?
10 REPLIES 10
Isn't this value 1 for both the first and the last layer?
