GDL
GLOB_STRUCTURE_DISPLAY for core+load bearing?
I am using GLOB_STRUCTURE_DISPLAY#1 to exclude the parts of the objects that are not "core".
It works with core only, but does not work with core only+load bearing elements, why?
Is there any other int number that represents such situation?
The problem for me is in the hosted elements like windows/skylights/doors.
There is a workaround...filter core+load bearing ->select ->3d selection ->core only - but it is cumbersome
2 REPLIES 2
MF BIM
Hi @Piotr Dobrowolski ,
I believe the Core of load bearing display is based on the Structural Function property so I don't think your sub elements can be impacted by this one.
https://mfbim.fr | https://youtube.com/@mfbim | My GDL course on Udemy, try it !
AC24 FRA 7600 - AC26 FRA 4027 | MacBook M1 Pro
If the sub elements were not affected, by the property they should not show in anything "core only.."
It is "core only" as a basis + some other property. So logically the behavior of the elements should be the same, as in core only + additional filtering by load bearing, but it is not.
I smell a bug.
