bimdo
gdl & renovation filter
Hi together
I'm looking for a variable, which is connected to the renovation filter, like for the structur filter.
GLOB_STRUCTURE_DISPLAY
Is there a solution or a variable to do the same with the renovation filter?
Archicad 25/26
Thanks a lot
Archicad / Archicad 28 / 29 INT/ CHE/ FRA
Windows 11
Jochen Suehlo
n = APPLICATION_QUERY ("OwnCustomParameters", "GetParameter(Renovation.RenovationStatus)", parValue)
TEXT2 0, 0, parValue
see here: https://runxel.xyz/Archicad-wiki/gdl/
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
bimdo
Thank you. I didn't explain the right thing or understood the command wrong. I'm looking for the status of the filter, so what's visible in the plan or model. When I understand your command right, you can extract the status of the element property, but not of the setted filter in the view... do you've a solution there too?
Windows 11
