perform coordinate transform in macro
Hi all.
Is it possible to perform coordinate transformation (e.g. add2, rotate2 ) in Macro?
MACRO OBJECT :
angleViewRot = 0
if dt then
rrr = REQUEST ("View_Rotangle", "", angleViewRot)
endif
totalRotate = (SYMB_ROTANGLE + angleViewRot) MOD 360
Rot2  totalRotate...
CALLER OBJECT/s:
 ! call macro object
! every unrotatable object i defined
Device name Asus v16
Processor Intel(R) Core(TM) 5 210H 2.20 GHz
Installed RAM 16.0 GB
1 Solution
Peter Baksa
The transformations done in the macro won't have an effect in the caller object. What you can do is calculate the transformation parameters and return them from the macro.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Go to post
1 Reply 1
Peter Baksa
Péter Baksa
